02-28-2013 12:19 PM
I have a Pixma MG6220 and I can't scan documents to my computer. I was able to do it earlier but now I don't have "use scanner" icon in my main menu and quick menu. Do I have to install some extra driver or what I can do? Because I lost my CD I installed it from Canon website, it has all same features, right?
01-09-2017 11:44 AM
windows 10
01-09-2017 12:03 PM
can not scan/ windows 10/ printing is okay/cannon mx 310
01-09-2017 12:35 PM
Hello Imaxpr!
Thanks for responding to our message!
The PIXMA MX310 is not compatible with Windows 10. We suggest downloading the Windows 7 or Windows 8 drivers to see if that allows you to scan. For the Drivers please go here: http://Canon.us/vxyv If not please contact our Technical Support Team by phone or email here: http://Canon.us/ContactCF
We hope this helps!
06-14-2017 05:18 PM
I have a Pixma mx472 printer. I press the scan button, the window says "please wait a while" and then nothing happens. Not sure what to do. Thanks.
11-18-2013 09:47 PM
I have Pixma mg5220 all in one; been using wireless for several years. I cannot scan - error message is that the printer cannot be detected. I installed new driver tonight (the MP one with wireless) and get same message over again that the printer can't be detected on the network. Performed easy set up on printer panel without a problem; easily found access points, etc. Installed a few weeks ago Bitdefender for 1st time -- could this have something to do with it? But has happened to me occasionally in past before Bitdefender with scanning, not printing, and had to reset with passphrase and all was OK. Been about a 4-6 weeks ago last used printer or scanner. Any advise? Very frustrating. Using Windows 7.
11-27-2013 08:06 PM
Hi mikikay,
Sometimes firewall, antivirus and spyware protection programs can prevent the printer/scanner from being detected on the network. If you temporarily disable the BitDefender program and then attempt to scan, are you able to scan successfully?
If this is a time-sensitive matter, additional support options are available at Contact Us.
09-12-2014 06:54 PM
01-10-2014 05:56 PM
I have a 2 year old mg5220. Just got a new laptop with windows 8.1, and now I cannot get the scanner to work from the operation panel. Navigator is installed, all drivers are updated and printer is showing up with network address in setup. I can print without a problem, and I can scan from Navigator. I can't get the scanning to work from the operation panel, which is what I use most often. When I try to set the pc on the operation panel, my laptop doesn't show up on the list. It sometimes lists just usb, and sometimes includes the other pc on my network. I checked the printer properties, and the 'enable bidirectional support' is not checked and I suspect that has something to do with my problem.
Does anyone have any other ideas? This is driving me crazy.
01-10-2014 10:35 PM
Solved my problem. For some reason, the scanner utility wasn't installed. I removed the printer and all drivers (good info on stragglers in this post: http://www.tomshardware.com/answers/id-1623188/catch-uninstalling-printer-drivers.html). I then reinstalled the printer, drivers, and navigator, IJ network tool and my canon printer software. Still wasn't having success, so in the process of poking around, I noticed that there was a canon network scan utility in the list of my installed programs, but it didn't show up on my list of apps. Searched on the name, it came up, clicked on it to open it. In the window that popped up it said if you plan on using the operation panel of the scanner via the network, select the name of the scanner from list below, then click ok. Once I did that, an icon appeared on my taskbar and it has worked perfectly ever since.
Hopefully this post will help out others spending ridiculous amounts of time trying to figure this out like I was.
02-18-2015 10:09 AM
This post fixed it for me, Just use the IJ network Scan utility......
