printer wont connect to my computer
Rose_pooran23
my cannon printer mg 2500 i snot connecting to my Asus Altec laptop. it is showing up bu tjust not connecting. am using windows 10.
1 REPLY 1
MG2500 and W10...
What driver did you use to install the printer?
I suggest this one
The driver requires that you run it  first, before connecting the printer.  Did you do that?  You then connect the printer to an available USB port and power it on.  Detection should occur.
If you are stuck, this might help.  See page 190
