01-02-2016 03:14 PM
thank you for sharing this site.
my canon pixma mg3520 printer wont print, yellow and green flashing light
01-02-2016 03:22 PM
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using and if you are connected via USB or WI-FI. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
11-07-2023 09:56 PM
Windows 10
11-15-2023 04:12 PM
Hi Tenpinrap52! Thanks for posting in the Canon Community Forum. I see that the yellow Alarm lamp and green Power lamp (lights) on your PIXMA MG3520 are flashing.
When both of these lamps are blinking, it normally indicates a mechanical (hardware) problem inside of the printer: I know the lights look as if they are constantly blinking, but if you look at them long enough you will notice a slight pause. You can wait for that pause, and then count the number of flashes (both lamps) until you see another pause. Once you know how many times the lamps are blinking (between each pause), you can visit the following section of the manual to find the error code that it represents:
https://ij.manual.canon/ij/webmanual/Manual/W/MG3500%20series/EN/UG/ug_trouble0300.html
When the page opens, you can scroll down to the section that has the information about both lamps blinking (power and alarm).
A paper jam or obstruction can accidentally trigger most of these errors. If you have not done so, I recommend that you turn the printer off and disconnect the power cable. Then, look for a paper jam inside the printer. If you don’t see a paper jam there, you can take the paper out of the tray and look for obstructions that may have slipped into the tray (pen, pencil, paper).
If you don’t find obstructions inside the printer or in the paper tray, you can reconnect the power cable. If the same error starts flashing after you turn the printer on, that means there is a mechanical malfunction inside the printer.
If you would like us to check if there are other options for the error that your printer is displaying, please write back and tell us how many times the lamps are blinking (between each pause). It will also help if you let us know when the printer was purchased and if you installed an ink cartridge immediately before the lamps started blinking.
I hope this information helps. Thanks again.
