09-02-2013 05:23 PM
My pixma mx922, when I attempt to print multi page doc's prints partial pages or only the last page then multi blank pages, I get message printer not responding. have been thru 2 sessions with canon tech support.no help. attempting to print using a usb flash drive with a 82k pdf file I get message format not supported or file to large??? ready to return to costco!!!
09-04-2013 05:16 AM
I believe the printer cartride alignment problem do that once again and you should be good to go.
If you still face the same error big kind of stuff try printing the same file through mobile it might work
As pc drivers and software easily get messed up.
11-02-2015 10:34 PM
I'm having the same issue. I'll try your solution and see if it works.
