pixma mx 860
swimrx
my pixma mx 860 is leaving browninsh little wet bubbles all over pictures that I'm printing... help!
1 REPLY 1
Patrick
Hi swimrx,
When printing does not appear as expected, first make sure that the ink is correct in your PIXMA MX860.  The correct order is:
CLI-221BK
CLI-221M
CLI-221Y
PGI-220BK
CLI-221C
Next, please perform a printhead cleaning.  Please perform the following steps to perform a Deep Cleaning:
 1.  Press the MENU button.
 2.  Select Maintenance then press the OK button.
 3.  Press <OK> to select Maintenance.
 4.  Select Deep Cleaning and press OK.
 5.  Press OK to select Yes.
The Deep cleaning will be performed.  After 2 or 3 cleanings, print another image.
The image should print correctly.  If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
