04-30-2021 02:03 PM
printer recognizes wifi, but pc is not recognizing printer when i try to install new printer
04-30-2021 02:09 PM
Hi, onelinda!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
04-30-2021 03:21 PM
05-19-2021 02:42 PM
Hi onelinda,
Please follow these steps:
1. Make sure that your PIXMA MX410 is turned on and contains paper.
2. Press the Menu button repeatedly until Device settings appears.
3. Use the left or right button to select LAN settings, then press the OK button.
4. Select Print LAN Settings and press OK.
The LAN Settings will print.
What is listed next to SSID? Is it the name of the network that your computer is connected to?
8 lines below that, what is listed next to IP Address?
