09-22-2013 04:24 PM
My MP160 Pixma printer shows a paper jam, but I have opened it up and checked and even blown it out and dusted it and there is no paper in it. I have even installed it on another pc and it still has that message! Any suggestion would be much appreciated! Thank you!
01-07-2014 07:12 PM
01-17-2014 05:26 PM
Hello blinkybud,
If you have checked for obstructions and removed any jammed paper, try resetting the printer:
1. On the operator panel, press and hold the ON/OFF button for one second. The display will go blank.
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the ON/OFF button again.
3. Wait until the device has completed its cycling process, and reattempt a print job.
If the issue persists, then, regrettably, the unit will need to be serviced. To contact our support group, click on the following link: http://bit.ly/ContactCanon
