mg5420 how to use auto duplex copy
annechung
I bought the 5420 just for the duplex copy but I don't know how to use that function. I'm into desktop publishing.
Thanks
1 REPLY 1
Patrick
Hi annechung,
To duplex copy with your PIXMA MG5420, please view this page from the PIXMA MG5420's manual:
Two-Sided Copying
When you select 2-sided for 2-sidedPrintSetting in Standard copy, you can copy two original pages onto the both sides of a single sheet of paper.
figure: LCD
Press the right Function button to select the stapling side.
  • When Portrait is selected for Orientation
    Long-side stapling
    Short-side stapling
  • When Landscp. is selected for Orientation
    Long-side stapling
    Short-side stapling
After selecting the stapling side and press the OK button, you can select whether you use the preview screen. If you select ON, the preview screen is displayed so that you can check the orientation.
When checking the orientation:
When you are using the preview screen, the screen below is displayed so that you can check the orientation.
figure: LCD
  1. Rotate
    If you press the right Function button, the original rotates by 180 degrees.
  2. Rescan
    If you press the left Function button, the original is rescanned.
Press the OK button to start scanning.
When scanning is finished:
The Document setting screen appears on the LCD after scanning each sheet of original.
figure: LCD
Remove the sheet of original from the platen glass after scanning and load the next sheet on the platen glass, then press the OK button.
For further assistance, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
