07-30-2014 04:26 PM
Hello,
I have an iP7220 which is used exclusively for CD/DVD printing. It was working fine yesterday but today it won't print black, just a very light shadow that looks to be blue. I pulled all the cartidges, replaced them and ran a Nozzle Check which came out fine. The alignment appeared to be off a little so I ran the Print Head Alignment which tossed back an error, Support Code: 2500. The message box suggested that the heads may be clogged but another run of the Nozzle Check said everything is fine. The printer is 4.5 months old.
Any help will be appreciated.
08-02-2014 08:27 PM
Hi symbiount,
Please try printing the alignment manually. First open the printer driver:
1. Click on Start and then Control Panel.
2. Click on Printers.
3. Right click the PIXMA iP7220 and left click on Printing Preferences.
Once the Printing Preferences appears, please follow these steps:
Click on the Maintenance tab.
Click Custom Settings on the Maintenance tab
The Custom Settings dialog box opens.
Switch head alignment to manual
Check the Align heads manually check box.
NoteIf the printer is off or if communication between the printer and the computer is disabled, an error message may appear because the computer cannot collect the printer status.
If this happens, click OK to display the most recent settings specified on your computer.
Apply the settings
Click OK and when the confirmation message appears, click OK.
Click Print Head Alignment on the Maintenance tab
The Start Print Head Alignment dialog box opens.
Load paper in the printer
Load three sheets of A4 size or Letter size plain paper into the cassette (lower).
Execute head alignment
Make sure that the printer is on and click Align Print Head.
Follow the instruction in the message.
Check the printed pattern
Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
When you have entered all the necessary values, click OK.
NoteIf it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
(A) Least noticeable vertical white streaks
(B) Most noticeable vertical white streaks
If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
(A) Least noticeable horizontal white streaks
(B) Most noticeable horizontal white streaks
Confirm the displayed message and click OK
The second pattern is printed.
ImportantDo not open the top cover while printing is in progress.
The third pattern is printed.
Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
NoteIf it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
(A) Least noticeable horizontal stripes
(B) Most noticeable horizontal stripes
08-03-2014 11:06 AM
Many thanks for the help. I was able to successfully run the alignment. Unfortunately, the problem persists.
Printing from the paper cassette in black, color or a mix was working fine and continues to do so. The problem is printing directly to inkjet printable CD's and DVD's. I have tested with three different disc manufacturers and two different software applications, however the results remain the same with each test.
When set to print a simple set of black text the output is a faint blue with an intermittent thin black border around some characters. When set to print in color, 6 colors across the spectrum were tested, the result is perfect. Again, this was tested with both multiple disc and software manufacturers for both black and color tests with uniform results.
Once again, any help would be appreciated since an inability to print black text renders this printer useless for our needs.
