06-28-2017 07:59 AM
help please
i use 4 a page address labels for posting items on ebay
i have a huge problem which in turn causes me bigger problems and wasted labels.
i cannot get the label i want to print off to rotate so the only section that will print is the top right hand corner. this means i can only use the sheet twice. if i peel off the remaining two labels and stick them back on in the appropriate place quite often they come off and wrap themselves around the roller of my machine.
i have a canon pixma mg3650 printer and have it set to the default setting.
i have tried the 4 label section and it just sends out tiny little labels that i cannot read.
i cannot find anywhere in the instructions on how to rotate a label so that i can print off all four labels. if i use royal mail to print a label it asks me where i would like the label to be and it works fine but cannot do it with paypal or ebay.. help please... kind regards jane
06-28-2017 01:26 PM
Hi jane31259,
Who is the manufacturer of the labels that you are using?
06-28-2017 02:10 PM
just bog standard 4 to a page labels..
06-28-2017 04:17 PM
Hello.
The printer driver does not have options for formatting labels or specialized layouts like the one you are trying to print. Try using a different web browser to see if the options change at all. If you continue to have difficulties, contact Paypal to see if they can suggest a program or method to print your labels.
