02-26-2021 03:10 PM
Hello. I just upgraded to MacOS Big Sur. I downloaded the latest drivers for this printer from the Canon's website, but they do not work. Can you please tell me if Canon has printer drivers for this printer and macos big sur? Thanks.
03-01-2021 12:54 PM
I have very good news. The printer driver was already installed in my computer. I just had to remove the printer from the list of printers in system preferences, and add it again. When I added the printer, the software appeared and was ready to use. Thanks for your help. Rick.
02-26-2021 11:30 PM - edited 02-26-2021 11:31 PM
The support site for your model shows MP280 series CUPS Printer Driver Ver.16.40.1.0 (Mac) as compatible with Big Sir.
You'll need the ICA driver 4.0.0.a to scan or the MP280 series Scanner Driver Ver.18.2.0 (Mac) which supports TWAIN compliant applications.
Not sure what driver you installed?
Support | MP Series | PIXMA MP280 | Canon USA
02-28-2021 05:06 PM
Hello. I "duplicated" my post because I did not realize that this was a different forum (Printer > Multifunction Support vs Printer > Personal Printing).
THe driver that you mentioned in your post is the one I Installed, but Big Sur says it is incompatible and it does not run under Big Sur.
Actually, when I visit the support site for my model MP280 Series, it says that it is detecting that I have macOS Catalina as my operating system, which is not correct. But if I go to the Operating System menu and select Big Sur 11.0, it shows the same driver as for Catalina. It should be a new driver.
In addition, I installed the scaner drivers and they were installed correctly under Big Sur. But what I need is the driver for the printer functions, not for the scanner functions.
I would like the Canon Tech Support to be aware of this issue so they can provide an updated printer driver.
Thanks!
02-28-2021 05:40 PM
In addition, I have a small problem with this forum. I am not getting messages in my Email when someone replies to my message. I have to come here in person to check if I have replies.
On the right column of this post, I have checked "email me when someone replies".
I have also checked in Canon Community > My Settings > Preferences and I have checked "automatically subscribe me to topics or reviews I participate in".
02-28-2021 07:46 PM
I went to the apple support forums and read that if the driver for this printer was updated on 10/02/20, it could not have been tested for Big Sur, which was released later. So I think Canon has to update the printer driver for Big Sur.
As a note: Big Sur is 64-bit. I don't know if the latest driver that Canon has for this printer is 64-bit or 32-bit.
Thanks.
03-01-2021 12:54 PM
