‎08-23-2013 10:43 AM
Anyone found a solution for Windows 8 to get the scanning function to work with the Imageclass 4150? Cannon has been in a state of denial about the problem.
‎08-25-2013 05:35 PM
Hi cleko,
It sounds like you have had some difficulty scanning. I'm sorry for your inconvenience and can appreciate your frustration. Scanning can be performed under Windows 8, however there are several possible causes that can interfere with doing so successfully, for example: TWAIN conflicts, how the driver was installed, connection type, Device Manager errors and OS conflicts with assorted devices to name a few. There are also several procedures that can be used to isolate and resolve these and other causes.
We will gladly take a look at your situation to help you scan. Even if you have contacted us previously, please allow us to make sure that all avenues have been checked for you by clicking this link to Contact Us.
‎10-26-2013 02:17 PM
Feel your pain. I never did get my 4150 to work with Windows 8 for scanning. So last week I bought an MF4880 (comparable new printer.) Worked great in WIndows 8 with the right drivers. then I made the mistake of upgrading to Windows 8.1, for which there are apparently no functional Canon drivers. So I'm back to where I started, except out a couple hundred more bucks. Canon's inability to keep up with drivers will make me look elsewhere next time.
‎10-27-2013 10:16 AM
On the sixth time speaking with Cannon support, they told me the problem may be that I have a manual switch box that let's two computers use the same printer. I did disconnect the switch box and reloaded the drivers and VIOLA it worked. But don't get too excited yet. As soon as I went back to the switch box, it stopped.
The other option is to downgrade to Windows 7, which did not have the issue. That is what I am considering doing right now.
‎12-01-2013 10:49 AM
HERE IS AN UPDATE. HAD THE ISSUE AGAIN A FEW DAYS AGO AND SPOKE TO CANON TECH. PREVIOUSLY, THEY TOLD YOU TO TRY RELOADING THE DRIVERS. HOWEVER, THEY CLEARLY NOW BELIEVE IT IS A WINDOWS ISSUE. THE IMAGE ACQUISITION SOFTWARE IS FREEZING UP. RIGHT NOW THE FIX IS TO GO INTO CONTROL PANEL .> ADMINISTRATIVE TOOLS > SERVICES> WINDOWS IMAGE ACQUISITION (WIA) > START AND LET IT TIME OUT > REBOOT COMPUTER. ALL I CAN TELL YOU IS IT WORKED FOR ME!
