Will the Canon SELPHY CP910 Compact Photo Printer work with Windows 10?
DebbieZ
I was wondering if the Canon SELPHY CP910 Compact Photo Printer will work with Windows 10? Also, will it work if hooked up with an external harddrive?
I do scrapbooking, and would like to have a small portable printer like this to print photos off my external harddrive.
Any help is appreciated.
Thank you,
DebbieZ
4 REPLIES 4
Michael
Hello.
The CP910 is not compatible with the Windows 10 operating system at this time.  The use of external hard drives is not supported with our printers.
For additional assistance or information, find more help at Contact Us.
Do you have an estimate for when Windows 10 will be supported for the Canon Selphy CP910? I own this device and I only have Windows 10 so this is very frustrating.
scolvin
I was able to install it by doing it in the "control panel". Type "control panel" in the Cortona search prompt in the task bar. The old style control panel will show up. Go to Devices, then printers and add the printer there.
bpupnorth
I found that if you set the Selphy to be it's own hotspot, wifi direct connection, and then connect your laptop to it, you can run the downloaded software. It will detect the printer and install. Then switch the Selphy and laptop back to your wifi network. The Selphy still works. I did this on 4 pc's. Hope this helps.
