Why does my Canon MP610 only print every other line when I print a document? Ink is full...
Dray
I've reset the printer to the factory settings.  The ink cartridges are all full.  I have not changed any settings on the printer.  I cannot figure out why i'm having this issue.  Help!  Thank you.
1 REPLY 1
Stephen
Moderator
Moderator
Hi Dray!
Welcome to the Canon Forums and thank you for your post!
So that the Community can help you better, we will need to know about any error messages you're seeing either on the printer or your computer, the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
It's also helpful to know if you're having this problem all the time, or only with certain programs or applications.
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
Thanks and have a great day!
