How to do two-sided printing on a PIXMA TR4720
CRogerBlair
I have a PIXMA TR4720 printer. How do I do two-sided (duplex) printing?
2 REPLIES 2
normadel
Look in the manual.  Page 251.
https://www.usa.canon.com/support/p/pixma-tr4720
DerrickL
Whiz
Whiz
From the printer manual
Follow the procedure below to use duplex printing.
 1. Check that printer is turned on.
 2. Press the Setup button. The Setup menu screen is displayed. Use the arrow keys to navigate the display.
3. Select ECO settings and then press the OK button.
4. Select 2-sidedPrintSetting and then press the OK button.
5. Specify settings as necessary.
• • Copy Select two-sided copying as a default.
• • Template print Select two-sided printing of template forms on the printer as a default.
• • Fax print Select two-sided printing of sent/received faxes, reports, or lists as a default.
