04-22-2020 09:56 AM
I am running Mac OS Catalina 10.15.4 and my Canon TS6320 will not scan. it will print fine but I get an error saying
"Failed to open a connection to the device (-21345)" when trying to open the scanner.
04-22-2020 10:05 AM
Hi, CKDesign!
So that the Community can help you better, we need to know exactly which application you're using to scan. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
04-22-2020 10:10 AM
I am just using the printer/scanner window that pops up under system preferences.
05-06-2020 01:31 PM
Hi CKDesign,
Please try scanning using the IJ Scan Utility. This can be downloaded from our web site:
Once installed, please use this application to scan.
For more information regarding the IJ Scan Utility, please use this link:
https://ugp01.c-ij.com/ij/webmanual/ScanUtilityLite/M/3.2/EN/SUL/Top.html
If you are unable to scan, what error code appears when you attempt to scan using the IJ Scan Utility?
