TS-9120 print/scan problem
verazee
I drew a couple small pattern, scanned into my computer and then printed.  The problem is that when I print what I have scanned all the designs come out to way to big.  How do I set up my printer to print to the original scale?  Thanks for the help.
3 REPLIES 3
Ronster149
I had a similar issue recently. I guess it all depends on what software you are using to print the patterns from. I was using Windows Photo Viewer. Right when I got to the print preview, it looked like it had blown the picture up. I finally realized I had to uncheck the box that said "Fit picture to frame". Once I did that, it printed in original size. Not much help, but worth a try?
Thanks for your help; I'll give it a try.
This was a good idea but it didn't work.  Now if I have a PDF and I tell the printer to print at 100% it will be the correct size.  Maybe I should save my pattern pieces as PDF's and see if that works.
Friends and Family
