01-16-2025 06:00 PM
I have a TR7520 that can't scan through ADF. It worked fine up till now. It feeds the document almost completely through then stops and spits out a blank paper from the bottom tray. I can copy and scan through the glass scanner if I load it manually.
01-21-2025 04:01 PM
Hi turboglide,
Please make sure that you are placing the original face up in the document feeder and following these steps:
https://ij.manual.canon/ij/webmanual/Manual/All/TR7500%20series/EN/UG/ug_l_03_03_c.html
Next, please load plain paper into the cassette of your TR7520 and then follow the steps:
1. Press the Home button on your PIXMA TR7520 one time.
2. Tap gear icon at the bottom of the printer's display.
3. Tap Maintenance.
4. Tap Print nozzle check pattern.
5. Tap Yes.
Once that test page prints, please take a photo of it and then please reply to this post with that image attached.
01-21-2025 06:32 PM
