12-11-2019 03:36 PM
I installed driver Canon TR4500 series Ver.5.70 and can print a Self Test Page from Linux Mint 19.2, but not a Test Page.
I found that Software Update had me replace cnijfilter2 version 5.70-1 with 5.90-1+1804+1ubuntu1
Here is the terminal output from the installation:
$ sudo ./install.sh
Canon Inkjet Printer Driver
Version 5.70
Copyright CANON INC. 2001-2018
Command executed = sudo dpkg -iG ./packages/cnijfilter2_5.70-1_amd64.deb
Selecting previously unselected package cnijfilter2.
(Reading database ... 311495 files and directories currently installed.)
Preparing to unpack .../cnijfilter2_5.70-1_amd64.deb ...
Unpacking cnijfilter2 (5.70-1) ...
Setting up cnijfilter2 (5.70-1) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
# Register Printer
Next, register the printer to the computer.
Connect the printer, and then turn on the power.
To use the printer on the network, connect the printer to the network.
When the printer is ready, press the Enter key.
# Connection Method
1) USB
2) Network
Select the connection method.[1]1
Searching for printers...
# Select Printer
Select the printer.
If the printer you want to use is not listed, select Update [0] to search again.
To cancel the process, enter [Q].
0) Update
Target printers detected
1) Canon TR4500 series (//Canon/?port=usb&serial=15DD81)
Currently selected:[1] Canon TR4500 series (//Canon/?port=usb&serial=15DD81)
Enter the value. [1]1
# Register Printer
Enter the printer name.[TR4500USB]
Command executed = sudo /usr/sbin/lpadmin -p TR4500USB -P /usr/share/cups/model/canontr4500.ppd -v cnijbe2://Canon/?port=usb&serial=15DD81 -E
# Set as Default Printer
Do you want to set this printer as the default printer?
Enter [y] for Yes or [n] for No.[y]
Installation has been completed.
Printer Name : TR4500USB
Select this printer name for printing.
12-12-2019 03:41 AM
Fedora and Ubuntu appear to be the only distros oficially supported.
While other Linux distro might/could work, there is no guarantee of support or function.
