09-16-2020 11:22 AM
I have a Pixma TS3122, which does not have 2-sided printing. However, I see that in Paper Handling one can choose Odd Only or Even Only, and that there is a Collate choice. So I figure you CAN print two-sided if you simply take the stack out and flip it and continue printing. What I can't figure out (old brain) is which settings to choose. If I print Odd Only and then flip to print other side with Even Only, do I also check the Collate button or not? And what do I choose for Page Order? Automatic, Normal, or Reverse?
Has anyone figured this out? I've tried, but I'm too cheap to waste the ink anymore! I print out books to read, so that's a lot of ink and paper. I would much appreciate an expert answer! Thanks.
09-21-2020 11:48 AM
09-21-2020 11:50 AM
Hi clarescanon,
The Canon Community Forum is not for immediate assistance. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE. You can also contact technical Canon Knowledge Base support at 1-800-OK-CANON (1-800-652-2666) Monday-Friday 8 am to 8 pm ET, excluding holidays.
We hope this helps!
09-23-2020 07:01 PM
10-13-2020 03:40 PM
Hi clarescanon,
By immediate assistance, she meant that by using that link you could either chat or call and talk with a Technical Support Representative.
In regards to your question, all that needs to be performed is to select "odd'. Once all of the pages have printed, reinsert them into the printer (so that you are printing on the other side) and select "even".
