10-17-2013 11:03 AM
Would anyone know whether I could use my pixma printer in France without a transformer? Does it sense the voltage and automatically adapt itself to it, or will a step-down transformer be necessary.
10-17-2013 11:07 AM
Sorry, the title of the message I just sent was insufficiently specific. Does a pixma printer automatically adjust itself to 220 volts in France?
10-17-2013 11:46 AM
Hi Bigal!
So that the Community can help you better, we will need to know exactly what equipment you're using. Any other details you'd like to give will only help the Community better understand your issue. Thanks!
10-17-2013 12:08 PM
Thanks for the prompt reply. I'm using a Canon PIXMA MG2022 printer I wish to use in France. I have an adapter for the wall plug. Will I need a transformer?
10-20-2013 08:26 PM
Hi Bigal,
The power supply of the PIXMA MG2220 is 110 - 120 V, 60 Hz and 200 - 240 V, 50 Hz. You may need a plug adapter to connect the U.S. type plug to an overseas socket or vice versa, but if the voltage falls within the range noted above, then no transformer/converter would be required.
Hope this helps!
10-21-2013 09:43 AM
Terrific. Thanks so much for confirming what I suspected. We'll have no problem, then, with our new Pixma. The Canon Forum is fantastic.
