Pixma mp600 have hard drive
nunu
my printer of 5 years recently quit working. Now that it is not working how do I clear the memory on it? Does it have a hard drive that I can pull out?
TIA
1 REPLY 1
Julius
Rising Star
Hello nunu,
The PIXMA MP600 does not contain any built-in hard drive or memory, so there is no need to worry!  We would recommend setting the printer back to its factory default settings as follows:
  1. Press the <HOME> (A) button.
  2. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Settings], then press the <OK> (C) button.
  3. Use the Easy-Scroll Wheel (B) or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the <OK> button.
  5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press <OK>.
  6. Press the <HOME> button to return to the HOME menu.
Note: Changes the settings back to the default (factory settings), except for the language for LCD messages and the position of the print head.
