05-22-2016 08:42 PM
Hi all! I am a brand new member here, so I apologize in advance if this question has come up frequently before or has been discussed ad nauseum!
I have an old Pixma ip8500 from (I think) circa 2005-ish or so, and after years of faithful service the print head has finally died. I see that qy6-0076 heads are often described as being a workable replacement for the qy6-0055 head my printer uses. Do people find this to be the case? Current prices for the qy6-0076 are significantly cheaper than those for the qy6-0055, so it would be great to have that as an option. Any issues or gotchas with using the newer head on the older printer?
Thanks very much for any advice!
05-24-2016 08:20 AM
Hi Whitemocha,
We ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) for assistance with determining the compatibility of the print heads for use with your PIXMA iP8500. A Canon technical support representative will be happy to help. There is no charge for this call.
