Pixma TS6020 error 9958
kimhib1
I am unable to use my scanner.  I keep receiving an error message that says
"A required file is missing or corrupted or settings are incorrect.  Try install again".
I have also received the error "jp.co.canon.ij.scanutilitylite.icadriver error 9958"
I have deleted and re-installed the printer over and over again, I have downloaded the drivers and even returned settings to factory default.  I have a mac, I have read through manuals and don't know what else to do.  I can copy fine, I just can't scan anything.  Please help!?
It might be easier for us to help if we knew what MAC OS you were running?
You must install the following driver in order to Scan:
ICA Driver Ver.4.3.4a (Mac)
This driver works with any MAC OS since ElCapitan and supports Catalina
Let us know how ot goes
7 REPLIES 7
Moderator
Moderator
Hi, kimhib1!
So that the Community can help you better, we need to know exactly which version of macOS is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
I am running Catalina 10.15.2 on my Mac
Thanks!
And after installing the driver I referenced above the result was???
Yes!  It worked!  Thank you so much!
Thanks for your reply, appreciate the feedback.
lizhiltzmartin
Thank you, very helpful for me too!
Friends and Family
