PIXMA TS3722: Print jam but no jam
ailurophile62
I ran out of paper during a print job. I've got a steady amber light and an error code of E03. I hit the OK button. I turned off the printer. I unplugged the printer. I rebooted the Windows 11 PC. A message says I've got a paper jam, but there's no paper jam. The ink cartridges don't move when I open the door. I tried the maintenance utility and got this message:
"The process could not be performed.
Check that the printer is connected to the computer and the power is on. If the printer is in use, wait until it is finished and try again. If an error has occurred on the printer, clear the error and try again."
ailurophile62
Sorry. It's a Pixma TS3723
5 REPLIES 5
Mike
Moderator
Moderator
Hi ailurophile62,
Welcome to the Canon Community!
So that the Community can help you better, we will need to know what model Canon equipment you are using. Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
ailurophile62
Patrick
Hi ailurophile62,
To resolve the E 0 3 error that you are experiencing with your PIXMA TS3722, please follow these steps:
1.  Please remove all of the paper from your TS3722 and then please disconnect the power cord.
2.  Once done, please look down through the paper path to check for jammed paper / foreign objects.
3.  Next, please open the front cover and look in the area around the ink for jammed paper / foreign objects, making sure to look in the extreme left and right sides.
4.  Please reconnect the power cord and turn your printer back on.
5.  Does "0" appear in the upper right corner of your printer's display?  If so, please continue.
6.  Repeatedly press the wrench and screwdriver button until 7 appears on your printer's display.
7.  Press the Color Start button 1 time.  Your printer will start making noise.
8.  When the noises stop, insert 1 sheet of paper into your printer.
9.  Press the Color Start button 1 time.
Did the paper feed through your printer?  If not, please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA TS3722 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support. A Technical Support Representative can determine the cause of the issue and resolve it or provide you with your available service options.
I went thru the first few steps but the error 03 does not clear. There is no paper jam that I can see. what can I do?
ailurophile62
I got a flashlight and looked into the guts of the machine along the paper trail, and lo and behold, there was indeed a paper jam deep in the abyss. I liberated the paper, and it's been hunky dory ever since!
1.4.26
