09-20-2021 06:53 PM
I've had the printer for 2 years; earlier this year I got a new wifi router and have had intermittent problems ever since. I get a message saying the printer is offline, even though it isn't. In the past I've been able to remove the device from the computer and reinstall it. That has always worked. Yesterday, though, the problem started and I can't fix it. I've rebooted the computer, the router, the printer. I've gone through the setup multiple times and now I can't even complete the download/installation process. I'm using Windows 10. I'm thinking it's a problem with the printer and the router not communicating, but I don't know how to get them to "talk" to each other. I'm more than frustrated. Any help would be appreciated! I've tried connecting the printer to the laptop using a cable but that doesn't work, either (the cable may be bad, though). Help!! Thank you!!
07-07-2022 09:51 PM
This is exactly my problem and the steps I have tried to resolve it. Mine does this:
Takes forever to start printing
prints only a few lines then ejects the paper
ejects a blank paper
prints the same few lines it did as the first one
then a blank sheet
It does this over and over again until it goes through my whol stack of paper if I'm not near it.
It also will randomly start doing it, hours after I've canceled print jobs from doing what I described above. I've reached out to tech a couple times and was disconnected and the others just buffered. Now it's after hours. I've had mine since last September and I just switched providers and equipment. I print a lot of documents so this is really messing me up because I'm having to do it all by hand now... Not cool.
02-14-2025 03:23 PM
I acquired this printer from work used. It worked previously now it wont' print. It either prints some of the document very faint or just a blank page. There is ink in the cartridge, did the clean and deep clean function. Still not working. What do I do?
02-14-2025 05:12 PM
Hi SteveYYZ,
I would recommend replacing the ink with new, genuine Canon ink cartridges.
Your PIXMA TR4520 is compatible with:
PG-243 Black
PG-245 Black
PG-245 XL Black
CL-244 Color
CL-246 Color
CL-246 XL Color
They can be purchased directly from Canon:
Ink for PIXMA TR4520 - Canon USA
08-24-2025 05:17 PM
I’m having same problem. Did all clean functions even. Reset multiple times. It’ll only print like 20% of the documents that I’m trying to print out then stop
