05-06-2020 06:23 PM
I updated my system to Mac Catalina 10.15.4, and now certain apps aren't working including my Canon Pixma MX492 IJ scanner; when I try to open the IJ Scanner it reports "The developer of this app needs to update it to work with this version of macOS. Contact the developer for more information." (the printer software seems unaffected and completely fine.)
So I downloaded and installed the driver updates (files from Canon named mcpd-mac-mx490-16_40_1_0-ea21_3.dmg and mac-mx490-1_6-mcd.dmg) and both claimed to successfully install, but I can't find the supposedly-updated IJ Scan Utility anywhere.
I've lost the use of my scanner. I'm a photo restorer, so scanning is crucial to my business. Doesn't seem fair to have to pay $20 for tech support to get this glitch taken care of. Can anybody please help? Thank you!
05-06-2020 07:50 PM - edited 05-07-2020 12:29 PM
With PC's and Mac's, installing something over the top of something which is already broken is not always the best course of action.
I would suggest removing/uninstalling the printer, its drivers and all software. Now restart.
Then install using the correct drivers for your MAC OS.
These are the two drivers you need for Print and Scan support under OSX Catalina 10.15.x
Printing:
MX490 series CUPS Printer Driver Ver. 16.40.1.0 (Mac)
Scanning:
ICA Driver Ver. 4.1.3a (Mac)
Available here:
05-06-2020 08:01 PM
Great, thanks Rick. (I did wonder about possibly uninstalling, but worried it might not fix the scanner and mess up the printer to boot.) Short of just dragging the Canon folder from my Applications folder into the trash, is there a way to select and system-uninstall the drivers/apps? Thank you!
05-07-2020 12:46 PM
Printer removal:
Reset Printing System... Note, this removes all installed printers, but is a good way to ensure a fresh start from a installed device perspective.
Apple menu > System Preferences > Printers and Scanners...
Now right or Control click to in the left hand list of devices to "Reset The Printing System"
Note again.. removes everything
Software:
If you have a Status Monitor running, c;lose or quit it. If you can't... try Force Quit.
Applications:
Drag anything and everything Canon to the recycle bin... should get prompted for Admin PW... then restart.
05-19-2020 02:53 PM
Hi writeval.
In addition to the steps taken, if you haven't yet done so, drag the Canon drivers for the Canon MX490 series to the trash. You may find them in the following folders:
Mac HD \ Library \ Image Capture \ TWAIN Data Sources
Mac HD (\ Library) \ Printers \ PPDs \ Contents \ Resources
This will ensure the older drivers are fully removed, and will not conflict with or try to supercede the newer drivers. Once those are removed, download and run the driver installations for the MX492 again.
07-03-2020 10:24 AM
