03-15-2013 09:31 AM
I have a paper jam in my printer, but cannot figure out how to open the back to find it.
Can anyone help? ![]()
04-15-2019 03:07 PM
Didn't help me..
I was getting a line on the printout so I used the printer functions to
a) Do a deep cleaning .. which seemed ok.. when it printed the results with no issue
b) Roller Cleaning which clunked a lot but it finished cleanly
c) Auto head alignment which jammed .. Removed the jammed paper . Shut off on, tried it again ,,, same thing the paper jammed. removed the jammed sheet lifting the top cover
d) went through the whole sequence of looking for any paper jammed that I could not see from the top .. nothing
Now anything I try to print, or any print nozzle check pattern or any print head alignment feeds, prints and jams.,
Note I was not having any jam problems at all before doing the roller cleaning. Will try that again .. to see what gives.
Any help will be appreciated. The printer has been pretty flawless for many years or light use. As I said it was fine I was just getting a vertical line in the printed result and tried to use the printer features to clean and align and zap .. it won't print without jamming now.
