08-04-2017 04:06 PM
My printer prints ok. However the problem with the printer is that if I print more then 2 or 3 pages, the paper gets jammed in the rollers and the paper will not go foward or back. I have to pull the paper out and the paper get torn because something is griping the paper and wont let go. I tried cleaning the rollers but it did not help. I tried different band of paper and did not help. If I want to print a test page, it will work very well. But if I need to print more then 2 pages, it gets all jammed up. Is there anything I can do to fix it. I am afraid that the repair cost will cost more than the printer. I have had the printer over a year and have only used it two or three times before it started doing this. I cannot take it back to Walmart because it was an open box item. Please tell me what to do.
08-04-2017 04:16 PM
Hi, a511475!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
08-04-2017 04:21 PM
Canon Pixma MP 495
08-05-2017 09:33 AM
Hi a511475
It sounds like you have already performed the recommended roller cleanings. Please click HERE to check for jams. If the issue continues, It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
