12-06-2022
06:16 PM
08:55 AM
I have a TR8600 that shows that all ink colors have sufficient levels of ink, and when I print a nozzle check from the printer it shows correct with all colors.
However, when printing form Windows 10 PCs I am not seeing all colors in the document.
When I print a test page from my Windows 10 PCs the test page only prints in CYAN.
I've tried this from multiple PCs and it is the same result each time.
Any ideas what would cause nozzle checks on the printer to show all colors, but then not use all colors when printing from a PC?
12-06-2022 06:59 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know the exact model Canon printer you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
12-06-2022 07:24 PM
This is a Pixma TR8620 with firmware version 1.050, using default Windows Print Drivers on Windows 10.
12-12-2022 12:32 PM
When you print a nozzle check, does it look like the example HERE?
12-12-2022 01:50 PM
Yes, it looks like pattern A (no gaps or breaks in the colors)
07-15-2023 11:41 AM
Did they ever find a solution? Mine appears to be same/similar problem. I get nothing out of Cyan
07-18-2023 02:28 PM
If you print the nozzle check any cyan does not appear, I recommend a cleaning and a possible deep cleaning. If cyan does appear on the nozzle check but not in your prints, make sure you have downloaded the Canon driver and are not using a built in Windows driver.
In some cases if you go into printers and scanners on Windows and select Add Printer, it will add a default Windows print driver. You will want to make sure you use the TR8600 series MP Driver Ver.1.04 listed HERE on the Canon website.
11-25-2025 09:32 AM
I'm printing using Windows 11. It only prints cyan. I've reinstalled the latest drivers. Even the Windows Printer Test Print only prints cyan. However, when I run the nozzle checks, all the colors print. It SOUNDS like it's printing, but only spits out blank pages unless the page uses cyan.
11-25-2025 09:34 AM
Sorry - the printer is a PIXMA TR8620.
11-28-2025 02:32 PM
Based on this type of issue, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you
