02-21-2024
07:20 PM
09:02 AM
After 6 years of continuous use, the right hinge of the printer's operation panel cracked. Now I have the panel propped up at an angle with a pencil to support the weight and alleviate the stress on the left hinge so it will not suffer the same fate. Does anyone know if this is a replaceable part? The printer works fine. Thanks for your input.
02-22-2024 04:03 PM
Spoke with the parts department and unfortunately the operation panel is not available as a replaceable item. Thanks for your assistance.
02-21-2024 10:55 PM
Welcome to the forum!
Our parts department will be able to check for possible availability of this specific part. You can reach them at: 1-866-481-2569, weekdays from 9 AM - 7 PM, ET.
02-22-2024 03:50 PM
Much appreciated. I'll reach out to the parts department.
02-22-2024 04:03 PM
