08-08-2023
06:26 PM
09:08 AM
After clearing a bad paper jam that resulted in Standard Code 6000, my MX922 will print from Notes and Omnis Studio but not from Word nor Acrobat (and poorly from Mail). I keep replicating these same results and so it does seem to depend on the application. TIA, Allan
08-09-2023 09:09 AM
Thanks for joining the conversation, lombardi3g!
So that the Community can help you better, we need to know exactly which version of macOS is running on your computer. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-09-2023 11:28 AM
MacBood Pro 2021 14"
Monterey 12.6
TIA, Allan
08-11-2023 01:47 PM
Please remove the printer from printers and scanners and then restart your Mac. Once the computer is restarted, click HERE and select software and drivers. You will want to reinstall the CUPS driver, ICA driver and Canon scanner driver along with IJ Scan Utility.
Once all files are installed, go back to printers and scanner and select the add printer option. Make sure Canon driver option and not Airprint or Bonjour when adding the printer back.
