PIXMA MX922 - Printer problems after Windows 10 update
gems
Hello i have canon pixma MX 920. No problems till three windows 10 updates last two days:  KB4522016 FOR .net framework 3.5 4.8.1 zzhz ; SERVICE STACK 10.0.19041.3562; KB5031224. i HAVE CHEcked control  panel and "set as default" bu each time i try to print, I get a FAX BOX that says select address and nothing will print. Just stalls.  Would greatly appreciate any help.  Thanks kindly.
3 REPLIES 3
If you believe the issues you are experiencing are due to recent updates, you can remove them using the windows update applet.
Select Start > Settings > Windows Update > Update history > Uninstall updates . View update history.
On the list that appears, locate the update you want to remove, and then select Uninstall next to it.
Then restart.
Thankyou very much.   I did try that but the uninstall option will not come up for that service stack update i listed above; the other two did unistall but same printer problems!
  • PS:  this an all in one printer faxer scanner cannon.  but since the update when I goto print, the SEND FAX SELECT ADDRESS box pops up on the left not the print/options box if that means anything.  thanks much
