01-29-2023
08:09 AM
08:19 AM
I am using a Canon MG2922 printer/scanner. I print 30 labels per page in a 10x3 grid. The last column of labels has a printing problem that I can't seem to fix. Please see the picture below. The left photo is the PDF: this is how the labels are supposed to look. On the right is my scanned-in image of the actual printed label. Notice the stars are cut off and "Romper" becomes "Rompe." How do I fix this?
01-30-2023 10:25 PM
What software are you setting up the labels in and printing from?
What specific label sheets are you printing on?
01-31-2023
06:36 AM
08:19 AM
Adobe Reader XI for Mac
Office Depot White Inkjet/Laser Address Labels, 1in. x 2 5/8in.
[Commercial link removed per forum guidelines and replaced with screenshot to facilitate discussion.]
01-31-2023 12:09 PM
Adobe reader is a viewer for PDF files. It is not where labels would be created. Did the person who created the label sheet just save it as a PDF file?
It sounds like the image doesn't fit the label sheet. If the only problem is that the right edge is cut off, but all the other rows fit correctly, consider the right row waste.
01-31-2023 04:17 PM
I also have Adobe Acrobat on my work computer and could edit the PDF if need be. Is there a way to see what the “print area” of a PDF is?
02-01-2023 01:22 AM
When you choose to print you see a preview of the page as it will print. What you see is what you get.
Creating a label sheet requires choosing the label page layout, like in Microsoft Word, for example. Then it is formatted to fit. I don't know if you can do that in Acrobat.
Sorry, I can't be any more help.
02-01-2023 03:15 PM
Well I tried updating the printer driver and that also did not fix the problem. Then I took the exact same PDF and printed it on another printer (a Brother printer) and that printed successfully. I guess Canon printers just suck.
