12-06-2024
11:19 PM
09:40 AM
When I first used the PIXMA G-7020 IJ maintenance tool to set the auto power on and off parameters, it worked well for one to two days. Then it stopped working, and I haven’t been able to get it (both auto on and auto off functions) working again. I haven’t tried going back into the IJ tool and disabling and re-enabling the functions again, but no luck.
12-10-2024 02:56 PM
Hi DrRussell007,
Please try changing the settings using the Operation panel of your PIXMA G7020. To do this, please follow these steps:
1. Turn your PIXMA G7020 on.
2. Press the wrench and screwdriver button one time.
3. Repeatedly press the right arrow to select ECO settings and press OK.
4. Use the right arrow to select EnergySaveSettings and press OK.
5. Press OK on Auto power off.
6. Use the left or right arrow keys to select from OFF, 15 minutes, 30 minutes, 60 minutes, 120 minutes or 240 minutes. Once you have selected the desired time, press OK.
7. Press OK on Auto power on.
8. Use the arrow keys to select ON or OFF and then press OK.
