12-03-2021
08:51 PM
09:18 AM
12-04-2021 11:04 AM
When you use "Automatically Select" in the printer driver, it will select the paper source based on the size of the page you are printing. You can register different paper sizes for the main cassette and manual feeder.
The easiest way to do this is to create a custom profile (preset) and set it as the default.
Canon : Inkjet Manuals : G7000 series : Registering a Frequently Used Printing Profile
If you select your custom profile and select "Always Print With These Settings" check box, the printer will use these settings unless you tell it otherwise.
12-05-2021 10:53 AM
Sounds like some overcomplicated procedeures.
Normally the printer feeds off the cassette, this is to be expected.
When user wants to use some special paper, he/she opens the rear tray and puts them there.
Now user still needs to manually select "rear tray".
But the logical and usual operation should be to prioritize the rear tray whenever it's loaded?
Cheers.
06-18-2022 12:14 PM
Any news?
07-19-2022 09:45 PM
Hi anyone?
07-20-2022 09:19 AM
Hi, loyukfai!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
06-17-2023 01:39 PM
Pity
