PIXMA G6020 - will only print in red or pink ink.
cahatala16
Hello,
I realize it's a Sunday.  I am wondering why my Canon PIXMA will only print in red or pink ink.  All of the ink colors are full.  Even if I click print in black and white on the printer it will only print in red ink.
Thanks
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, cahatala16!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
Patrick
HI cahatala16,
To resolve the printing issue that you are experiencing with your PIXMA G6020, please follow all of the steps provided on this page from the manual:
G6000 series > Maintenance > If Printing Is Faint or Uneven > Maintenance Procedure
normadel
Well, you don't say what printer you have, so I'll just educate you....
Your printer has Cyan, Magenta, and Yellow inks, and black. I emphasize Magenta because that might be what you're calling Pink, which it isn't.
Red is produced by superimposing Magenta and Yellow. So it is using these two colors.  Some Pixmas use all four colors when printing Black. So your problem is it is not using Cyan and Black to print blacks as it should.
You could have clogged nozzles on your printer. Try doing some maintenance test prints, nozzle cleaning prints, and deep-cleaning prints, to see if you can get Cyan and Black inks flowing.
