04-22-2020 10:50 AM - last edited on 04-22-2020 11:44 AM by Danny
PIXMA G6020. Yesterday, 4/21, printing with no problems. Today, 4/22, cannot print from the cassette. I have ensured all settings are correct, etc. etc. How ridiculous. I'm trying to work from home and this is creating serious problems for me.
04-22-2020 11:39 AM
Strange that when I print from Adobe, it prints from the cassette. When I print from Word, it forces me to print from the rear tray.
02-07-2021 02:07 PM
Hello I am experiencing this problem also. The printer refuses to print from the bottom cassette.
I have tried all the trick I have seen in this community, but still, it won't.
Any hints?
03-13-2021 03:23 PM
Check the settings in your printer dialog box when you print. Some computers (especially Macs, I think) have an option to "use previous settings" or something like that. If that box is checked and you have previously used the rear tray, then it will always try to use that tray.
The setting may be somewhat buried, especially if you are using Google Docs. You may need to go beyond the Google Docs print settings dialog box and get to the Operating System dialog box before you can access the functions.
In my opinion Google Docs + Mac OS is a terrible setup.
08-26-2022 06:57 PM
So what's the solution? This is ridiculous! Help please!
01-04-2023 10:03 PM
I know! I’m about to throw this printer out the window. Can’t print from cassette paper tray even when I select it! I’ve never used the rear tray so it isn’t defaulting back. This is ridiculous!
05-14-2023 01:30 PM
I had to call Asurion Tech Support (which I purchased with this printer) to get this answer. After loading paper into the cassette tray, ALSO put one piece of paper in the rear tray. Then print from your computer. VOILA! Because OK was pressed after loading paper into cassette tray it prints from the cassette tray. The piece of paper in the rear tray just tells the printer that set-up is complete. How silly is this??? VERY SILLY! But it works.
11-27-2023 02:01 PM
SOLVED for MAC
I tried everything from the printers extremely minimal settings to Mac’s printer settings and no matter what it would ALWAYS try printing from rear tray. To solve this issue you must go into the printer administrator setting in your web browser:
Go to ^that^ website
Click the printer in question. There will be 2 dropdown boxes (Maintenance/Administration)
Click Administration and choose “Set Default Options”. Choose your settings, for Media Source choose “Main Tray” and select “Set Default Options” then type your username & password to submit (same username & password you use to unlock your computer). When you go to print, in the dialog box make sure “Default settings” are selected. BOOM.
Note - when you create a new preset in the print dialog box it will revert back to the infuriating rear tray preset. So always use default setting since it’s based off what you selected in the administrator settings.
12-29-2023 03:22 PM
To print from Cassett.
Open Windows control panel
Go to Devices and printers
Click on your printer
Click Display print properties
Scroll down, click on Preferences
New screen
Scroll down to Media Type
Chose Letters 8.5X 11
Scroll down to paper source.
Arrow down to Cassette
Check box, Always print w correct settings.
Click Media Info
New screen
Click SET
Then Apply
05-24-2024 03:42 PM - edited 05-24-2024 03:42 PM
I had a similar issue. When I tried to copy at the printer, it would give me a 2114 error because there was no paper in the rear tray. I tried to force it to use the cassette, using the copy settings from the printer control panel, but the only options available were *Auto and Rear Tray.
To get around this, I forced it to reset ALL printer settings, by doing this:
This should reset everything, and you should be able to tell it set paper source to Cassette.
