10-03-2013 10:14 AM
I recently purchased the PIXMA 922 and have been having issues printing. I have put standard Staples copy paper in the lower tray. When I go to print it will sometimes print a page or two, then it gives me "Support Code 1008" error saying there is no paper. I have to open the lower tray, readjust the paper a bit, hit ok. At that point its about a 40% chance of printing another page or two, otherwise it thinks again and then gives the same error. It makes it almost impossible to print anything more then a couple pages since every few pages is spending a few minutes going back and forth with the printer. Did I get a lemon? Is there something I missed that would make it so the printer can't pick up the paper? Before I return the printer I wanted to try to get some assistance.
Thanks!
04-18-2018 12:09 PM
Hi Lpottenger,
The error caused by:
1. There is no paper in the cassette (lower).
2. The paper source is incorrect.
3. Paper is not loaded properly.
To resolve this, please place paper in the lower cassette, making sure that the photo paper or plain paper such as A4, B5, A5, 8" x 10" (20 x 25 cm), Letter, or Legal, or envelopes are loaded.
For more information regarding loading paper, please view the following page from the On Line Manual of your PIXMA MX922:
http://ugp01.c-ij.com/ij/webmanual/Manual/W/MX920%20series/EN/BG/Bg-Loading1400.html
When the paper is in place, align the paper guides with the both edges of the paper and the press the OK button to dismiss the error.
Once set, please make sure that the printer driver is set to the lower tray:
***Windows***
1. Click the Windows Start button in the lower left hand corner and then the Windows System folder.
2. Click on Control Panel.
3. Click on View devices and printers.
4. Right click the PIXMA MX922 and left click on Printing Preferences.
5. Click on the Main tab.
6. Please set the Media Type to Plain Paper and the Paper Source to Cassette.
7. Click Apply and then OK.
***Mac OS X***
1. Open your item that you wish to print.
2. Click on File and then Print.
3. Click Show Details.
4. Select your paper from the Paper Size drop down menu.
5. Select Quality & Media from the drop down menu.
6. Select your type of paper from the Media Type drop down menu.
7. Choose Cassette from the Paper Source menu.
Please attempt to print.
05-06-2018 11:36 PM
11-28-2018 12:29 PM
My Pixma 922 will not use paper in bottom tray. It states "there is no paper in the upper tray. Please load and try again."
I do NOT want to use the top tray. I am trying to print an 81/2 x 11 paper from the bottom tray.
What can I do to make it use the bottome tray???
12-03-2018 04:34 PM
Hi mcholt2010,
***Windows***
***Mac OS X***
If you are printing from a Android or Apple device, please make sure you have the Canon Print Inkjet/Selphy app installed.
01-19-2019 12:55 AM
This did not fix the problem. I have tried everything. If you do a search on this, there are tons and tons of people having this exact same issue and this guy keeps repeating the same thing that does not fix the problem. Definition of insanity maybe? Too bad too this printer was my favorite I've owned until this not loading paper problem. I've even pulled the tray out to watch the rollers engage rarely.
01-22-2019 12:39 PM - edited 01-22-2019 12:40 PM
Hi travismeek,
If the rollers are not engaging, your printer will require service. If your printer is less than a year old and you have a copy of the printers receipt, please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
If your printer is out of warranty, you can take the printer to any repair shops in your area to fix the printer. You also qualify for the Canon Upgrade Program.
This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 seven days a week, 8 AM to midnight EST. Let them know you have been working with technical support and that the Canon Upgrade Program was offered.
12-02-2019 04:26 AM
I've been struggling with this recently and none of the other solutions on this forum seemed to be working. Just now, I tried gently pushing the paper to the back of the slot with my finger and holding it there until the printer finally took the first piece, and from there it decided to work. Posting this in case it helps anyone else
11-28-2020 02:51 PM
I have tried all of these so,unions multiple times over the last 10 months and nothing corrects this. The printer was only a few months old when it started doing this. I use it to print mostly 4-H things for my 4-H club but have had to get everyone to print th8ngs for me this year. How can I get this to work?
04-14-2021 03:00 PM
I have had my MX922 for about a year. Almost every time I print more than a few pages one will get stuck at the back of the bottom drawer. Now I am getting en error code of 1008 that there is no paper in the tray. The tray is full. I cannot copy or print anything. The last thing that happened was a page got jammed in the back of the bottom drawer. I pulled it out. It came out whole. I checked to see if there were any pieces anyhow. There is nothing.
