PIXMA 432 print is cropped
peaches2165
I have a PIXMA 432 and when I print 4x6 photos the top portion of the photo gets cropped.  I use a 4x6 and put it in the printer long ways and use fill print.  I tried a couple of different options and with the options I get a white border which I do not want.  Any suggestionson how to fix?
Thanks
1 REPLY 1
Michael
Hello.
If you are using the borderless printing option, you may expereince a cut off of the outside areas of the image.  To prevent this, use the bordered option instead.  This will allow you to retain the whole image with the printout.
If you continue to have difficulties, try using our Easy-PhotoPrint EX program to print the photo.  It is available at www.usa.canon.com
