02-28-2021 04:49 PM
My PC stopped printing to my MX870 series printer (which I have had for years) so I removed the driver and re-installed the latest version. But I only my FAX and Scanner functions are installed. The printer setup seems to fail. I tried several times without success. Have done this before without problems. Here are the setup results
Model Canon MX870 Series
Network Setup of the Printer Failed
Name
Port Name CNBJNP_001E8FED3B4A
Network Setup of the Scanner Completed
Name Canon MX870 series(00.1E.8F.ED.3B.4A)
Network Setup of the FAX Completed
Name Canon MX870 series FAX
Port Name CNBJNPFAX_001E8FED3B4A
Any idea what is going on and how to fix?
04-02-2021 01:14 PM
Hi lakram,
Reinstalling will resolve this issue. To do this, please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon MX870 series and left click on Remove device. Repeat until all MX870's are removed.
5. Click 1 time on one of the other printers installed.
6. At the top, click on Print Server Properties.
7. Click on the Driver tab.
8. Click on the MX870 in the list. Click the Remove button at the bottom.
9. Choose Remove driver and driver package and click OK.
10. Click Yes and then Delete.
11. Repeat until all MX870s are removed from the list.
12. Click Close to close that window.
13. In the upper left corner, click on Control Panel (or the Back button).
14. In Control Panel, click on Uninstall a program (or Programs and features, depending on your view).
15. Click once on "Canon MX870 series MP Drivers" and then click Uninstall at the top.
16. Follow the on screen prompts to uninstall the driver. When you click Complete, the driver is uninstalled.
17. Once done, please reboot your computer.
When your computer restarts, we will reinstall:
1. Please use the following link:
2. Click the Select button next to "MX870 series MP Driver Ver.1.06 (Windows)".
3. Click the Download button. The drivers will download.
4. Once the download is complete, open your downloads folder. To access this, press CTRL and J, then let both go.
5. Double click "mp68-win-mx870-1_06-ea24.exe" to begin the installation.
6. Follow the on screen prompts to reinstall.
Once the installation has completed, please attempt to print.
