03-08-2014 11:22 PM
I have had my MX892 printer for about 2.5 years without any issues. Today it will no longer turn on, display do not even light up. However, if I unplug it for a few minutes and then plub it back in and then press the power button and hold it, the display does turn on for less than a second and beeps and then turns off again.
Is there anything I can try to correct this issue?
01-17-2015 09:47 AM
Same here - Search Google - These guys MX892 are dropping like flies
01-24-2015 12:14 PM
01-24-2015 12:19 PM
02-09-2015 02:11 PM
I've got the same issue with my printer. Has anyone successfully fixed the problem? I'm hesitant to pay $20-$50 to see if someone can fix it without knowing the likelihood of success. I don't really want to toss the printer, but I'm leery of the possibilities of fixing it. Tech Support through Canon was useless!!
02-10-2015 12:36 AM
For what it is worth, I tossed mine and bought a new printer. Tired of wasting time with poor tech support with no answers
Jim
02-12-2015 04:29 AM
Hi LauraAlder,
When the printer will not power on, we recommend the following:
1. Ensure that the power cord is plugged securely into the printer, as the cord may have slightly become disconnected and prevented full power to be received by the printer.
2. Ensure that the printer is plugged directly into a wall outlet instead of going through a surge protector that is plugged into a wall outlet, as sometimes ports on a surge protector may no longer work, even if other ports on the protector do work.
3. Unplug the power cord from the back of the printer and from the wall outlet/surge protector and leave them out for at least 10 minutes, then plug it back in to try and reset the printer.
4. Try plugging the printer into another power outlet in a different area of the room, or another room if possible.
5. If you have another power cord you can use with the printer, please see if using that power cord will allow the printer to
power on.
If the printer still does not turn on after following the above steps, we recommend having the unit looked at by a service facility to determine why the unit will not power on. Please call or email us using one of the methods on the Contact Us page for servicing options.
02-25-2015 06:00 AM
Looks like I am having the same issue!!! I've only used this printer a handful of times and now its completely dead. Does Canon acknowledge that there is a problem? Are they willing to fix/replace these?
03-04-2015 03:28 AM
Hi saftab,
If the troubleshooting steps recommended earlier in this thread did not resolve the power issue the printer is experiencing, the printer will require servicing. Please call or email us using one of the methods on the Contact Us page for servicing options available to you.
04-29-2015 10:08 PM
Mine died too
05-01-2015 12:41 AM - edited 05-01-2015 12:43 AM
So after leaving the unresponsive printer unplugged for 24 hrs I tried to plug in and turn on, I got a B200 error, so I read another forum on here about that error. A person said to follow these steps:
"Here is what worked for me: 1. Turn OFF Power 2. Open the print head bay (as though you were about to change inks) 3. Turn ON power 4. Wait for print carriage to start moving to the left and let it go past half way 5. Before print carriage reaches left hand side (but after going halfway across) shut the cover. 6. Leave the Printer turned on 7. Good to go. It took 2 attempts before it worked. Some people said it took 3-4 attempts. Now, prior to this, I did clean the pads the cartridges sit on and used a qtip to wipe the encoder strip. I`m not sure if it was the combination of those things or just doing the fix."
This actaully worked for me without any cleaning 🙂
