10-23-2020 03:47 PM - edited 10-23-2020 03:51 PM
All-
So I've been wrestling with this issue of the scanner not being found by the IJ Scan Utility Lite under Mac Catalina 10.15.7 where it wasn't finding the scanner and throwing the pop-up error:
Cannot communicate with scanner. Possible reasons:...
I could print fine but could not scan. Printer was installed with Setup from the support page and added using Airprint Secure, but could not be found by IJ Scan Utility Lite. However my Windows box finds the scanner portion of the printer fine. I finally broke down and called support and I got it working. Specifically, IPv6 needs to be turned off on the printer. To do this:
And you're good to go. Hopefully this will save some frustration and time for others.
-G
09-29-2021 09:03 PM
thank you. this did not work for me. anyone else? i just bought this printer. installed all the drivers etc. still does not recognize my computer for scanning.
09-29-2021 09:05 PM
in fact for some reason that just disabled the wifi on the printer. help!
05-26-2025 06:13 PM
Followed your directions and went back to Home screen. IJ Scan Utility still gives message unable to connect or find scanner. Printer and Scanner in Settings shows printer, however when trying to open scanner, no scanner appears. After being on the phone with Apple for an hour they are positive it's not a Mac problem!
