09-06-2014 08:18 PM
09-24-2014
02:19 PM
12:23 PM
Hi kenne26735,
To resolve this, please place paper in the upper cassette, making sure that the small size photo paper such as 4" x 6" (10 x 15 cm) or 5" x 7" (13 x 18 cm), or Hagaki are loaded. Please note that if you cut plain paper into small size such as 4" x 6" (10 x 15 cm) or 5" x 7" (13 x 18 cm) and try to print on it, the paper jam will occur.
Once the paper is in place, align the paper guides with the both edges of the paper and the press the OK button to dismiss the error. Next, please make sure that the printer driver is set to the lower tray:
1. Click on Start and then Control Panel.
2. Click on Printers.
3. Right click the PIXMA MX922 and left click on Printing Preferences.
4. Click on the Main tab.
5. Please set the Media Type to Plain Paper and the Paper Source to Cassette.
6. Click Apply and then OK.
Please attempt to print.
If you continue to have difficulties, please contact our support group using the following link:
https://canon.us/account
01-12-2023 12:15 PM
The solution provided did not solve the problem and the link provided for further assistance doesn't work either.
01-12-2023 12:25 PM
Hi, unclegeo6! Thanks for pointing out the outdated link to us. This thread is from over 8 years ago and we've overhauled our web site since then. We've updated the link above accordingly, and if you also need help with your PIXMA MX922, you're welcome to contact our support team about it. Just register your printer here first and you'll get access to all of your support options.
Hope this helps!
