07-04-2017 06:05 PM
Below is a LAN setting printout. It does not appear to be the wireless connection.
Windows 10.
After clicking the print button on the PC, there is a 2 - 5 min delay before anything happens at the printer. The print queue immediately shows the document "printing." Usually a popup indicates "printer not responding." I'd appreciate any suggestions how to resolve this.
Recently, the printer seemed to lose my PC, showing only "local USB," and would not scan from the printer console, that problem has been resolved (but perhaps the two issues are some how connected).
This printer has always been slow performing some functions, primarily scanning - spending a lot of time warming up and processing, but usually printing, copying, and faxing have worked well.
Wireless LAN
Connection Active
MAC F8:OD:60:41:B4:34
ssid PAPAGIGI
Com Mode Infrastructure
Channel 6
Encryp AES
WEP Key L. Inactive
Auth WPA2-psk
Sig Str 100%
TCP/IP IPv4 & IPv6
IPv4 Addr 192.168.1.113
def 192.168.1.1
Subn Msk 255.255.255.0
IPv6 Addr ........
def ........
Subnet Prefix 64
IPsec
Security Protocol
Wireless LAN DRX Enable
07-05-2017 06:41 AM
Hi GWT,
There may be a program running in the background causing this issue to occur. Rebooting your computer without your normal startup applications running may resolve this issue. To do this, please follow these steps:
1. Put the cursor over the Windows Start button and press the right mouse button and click on Control Panel with the left mouse button.
2. In Control Panel, click on System and Security.
3. Click on Administrative Tools.
4. Click on System Configuration.
5. If you are prompted for an administrator password or confirmation, please type the password or provide confirmation.
6. Click on the General tab.
7. Click Selective startup and then uncheck the Load startup items check box.
8. Click Apply and then OK and then click Restart.
9. Test the unit at this point to see if the issue continues.
To return your computer to normal startup mode, follow steps 1-5 above, put a check in the box next to Load Startup Items, and then choose Normal Startup (if it was set this way initially) and click Apply. Click on the Services tab and click on the Enable All button. Click Apply, then OK and restart your computer.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
07-05-2017 11:12 AM
Thanks, for the info.
The problem is fixed, but not sure why because I was not disciplined. It began working properly after several total sysem reboots. I cannot say what specific step actually did the trick, frustrated, I was using a shotgun approach - everything off then everything on.
03-01-2021 11:34 AM
First problem was the lag time, but ended up with the printer in fax mode and couldn't get it back to print. Tried lots of things, and not being savvy, I had no idea where I'd ended up. ![]()
With the thought I'd have to call my IT person anyway, I made the bold move (for me anyway!) to uninstall and re-install the printer, hoping my wireless would magically connect.
It did!! Now prints immediately.
