12-14-2019 02:04 PM
Hello everyone,,
I have a 3 year old MX922. Recently some of the text has been blurry. I did as print nozzle check pattern and the PGBK section comes out blurry in the middle, as though it is printing the grid and a shadow. All other color sections are fine until the Ver 2.020 on the bottom which is blurry again.
I tried
1) Clean
2) Deep Clean
3) Auto Align (did not try manual align)
4) Changed all cartridges
5) soaked / cleaned print head in ammonia, distilled water and alcohol
6) Cleaned thin transparent plastic strip in the back with q-tip and neutral detergent
Nothing fixes this.
Then I tried printing out an excel spreadsheet with lots of random numbers. I tried changing different rows colors from light blue to dark blue to black.
Only the pure black rows printed fuxxy. The dark dark navy black rows print fine.
Can I assume 1) that the two metallic squares are print heads for a) color (including BK) and b) PGBK and that the PGBK secvtion of the print head having a software head alignment problem which causes it to move out of allignment every 100 or so "dots" or printer increments? Is there anyway to fix this?
12-15-2019 11:19 AM - edited 12-15-2019 11:22 AM
Greetings.
Some of the chemicals you are using might be a little harsh.
I'd stick with alcohol and distilled water.
What happens if you change the print quality, but leave the paper type as plain?
If the behavior persists, I believe you will need to replace the print head.
04-10-2020 02:18 PM
I have the exact same problem. does Canon have any fixes?
09-27-2020 12:17 PM
I too have MX922 with blurry print but mine has blurry print every two of three lines.
Is there solution?
