MP560
LJ5579
I need to turn OFF all wifi and bluetooth on this printer. Does anyone know how to do this? I use a desktop iMac if that matters.
2 REPLIES 2
JayC1
Hi. Thank you for your question. You can disable the printer’s Wireless LAN (Wi-Fi) function by doing the following: 1. Turn the printer on. 2. From the Home screen, use the Easy-Scroll Wheel to select the SETTINGS icon (tools), and then press the OK button. 3. Use the Easy-Scroll Wheel to select DEVICE SETTINGS, and then press OK. 4. Use the Easy-Scroll Wheel to select LAN SETTINGS, and then press OK. 5. Make sure that WLAN ACTIVE/ INACTIVE is selected, and then press OK. 6. Use the Easy-Scroll Wheel to select DISABLE, and then press OK. More information about making changes to the printer settings can be found in this article: https://support.usa.canon.com/kb/index?page=content&id=ART131320 The MP560 cannot be detected via Bluetooth unless you have purchased a BU-30 adapter and have it connected to the USB port on the front of the printer. If the BU-30 adapter is connected, you can disconnect. More information on using the printer with Bluetooth can be found on this web article. https://support.usa.canon.com/kb/index?page=content&id=ART132212 Thanks again.
Thank you so much! That did the trick. I so appreciate you getting back to me with simple instructions. Thank you!
Friends and Family
