05-31-2022 08:10 AM
My cannon MG7520 printer will turn on and start to go through its normal routine, but then unexpectedly turns off. The power cord has been checked, unplugged and replugged. Same result. Looking for other solutions if there are any.
06-03-2022 06:14 PM
Your satisfaction is important to us, and we apologize for any inconvenience you may be experiencing. A firmware update is available to fully resolve this issue. You can download the firmware update and find easy installation instructions at canon.us/power.
05-31-2022 11:27 AM - edited 05-31-2022 11:29 AM
Strangely enough this same thing just started happening for me today as well. With my MG7520 printer. Haven't used it in a few days. But today when turning it on, it goes through a cycle of internal printer head movement or whatever for ~20 seconds, then just turns off. Tried removing print cartridges as well, same issue. No error messages on the screen before it turns itself off.
05-31-2022 12:01 PM
I am having the same issue, which started today.
05-31-2022 01:00 PM
MG7520 printer. The printer starts and turns off after 15-20 seconds. IF I can get it to turn back on, I receive “The printer was not turned off correctly…” message. Usually it starts through a cleaning process and shuts off. I have discovered today, that if it turn off my router, the printer acts normal. As soon as I turn on the router, 10-15 seconds later, the lcd screen freezes and the printer turns off. I have tried resetting the wireless settings with the same outcome. This started happening within the last week or two. I’ve never had this issue in the past.
05-31-2022 01:04 PM
MG7520 printer. Same story here, 5/31/22! About 20 seconds of power up time, then all shut down.
05-31-2022 01:17 PM
I was getting ready to toss MG7520 in the trash this morning. This can’t be a coincidence among 5 different printers. Is 5/31/22 planned doomsday for the MG7520?
05-31-2022 01:28 PM
Same.
Yeah, and I can't find anyone else with this exact problem prior to today.
05-31-2022 01:39 PM
I was searching this morning for the “power was not turned off” message and came across this post regarding turning off your router/access point:
Power-was-turned-off-incorrectly-the-last-time
My MG7520 seems to function normally until I power up the router—frozen screen, shuts down. If I leave the router on and power up the printer, I may get to the message again or it just shuts down while cleaning.
05-31-2022 02:22 PM
Whoa. Yes, same 5150.
My MG7520 is set up to do network printing over wifi. If I have router on/ wifi connected, printer shuts down as discussed above.
If I turn off wifi/ router, printer boots up normally. I used the 'copy' function on the printer, and a copy was printed as expected.
So there's an issue just when connecting to network.
05-31-2022 02:26 PM
I’m having the same problem today. I’ve tried unplugging the printer and turning it back on but the same thing happens. Has anyone figured out what is going on?
