03-14-2020 03:36 PM
03-14-2020 03:50 PM
03-14-2020 04:30 PM
Hi, Ange1!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
03-14-2020 05:39 PM
03-16-2020 04:03 PM
Hi Ange1,
Please perform a test of your PIXMA MG5520:
1. Select SETUP from the HOME screen of your PIXMA MG5520. It is the wrench and screwdriver icon.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example below.
Does your Nozzle Check print correctly?
