07-21-2016 10:26 AM
I filled out a google form for a letter, but when I tried to print it, all I got was very light type. The next time, I did not get anything. All ink cartridges are OK. Tried re booting, but no luck. Won't print anything from internet or from my computer (Word files). Any suggestions?
Thanks
07-24-2016 11:07 AM - edited 07-24-2016 11:07 AM
Hi Manduca,
First, please make sure that the ink tanks are installed in your PIXMA MG5420 correctly and are in the correct order. The order from left to right is as follows:
CLI-251M
CLI-251BK
CLI-251Y
PGI-220PGBK
CLI-251C
Next, a test of your PIXMA MG5420 should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5420 and follow these steps:
1. Press the <HOME> button on your PIXMA MG5420.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this message. If they differ, please perform a few printhead cleanings. To perform cleanings, please follow these steps:
1. Press the <HOME> button again.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly? If not, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
